This is an update log about my build upgrade situation
THE SYSTEM I HAVE RIGHT NOW
My disgusting system after 3 weeks of not cleaning
CPU: Intel Core i7-2600K Quad-Core processor 3.4Ghz
Motherboard: ASUS P8Z68-V
(http://www.asus.com/Motherboards/P8Z68V/)
Memory: Corsair Vengeance 16gb DDR3 1600MHz
Storage: Intel SSD 335 series 240 GB, Seagate 2TB 5400rpm Drive
Case: Antec Lanboy
(http://www.antecindia.co.in/product.php?id=NzA0MzE3)
Sound card: Xonar DGX
Graphics card: PNY GTX 580 1536MB 384-Bit GDD5 PCI Express 2.0x16 HDCP Ready SLI Support with CPU cooling
(http://www.newegg.com/Product/Product.aspx?Item=N82E16814133398)
Power Supply: Corsair AX 750 -80 PLUS GOLD
(http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139016)
This thing is a dust magnet. And also I have few overheating issues and what not.
WHAT I WILL BE UPGRADING
Case: NZXT H440(Red & Black edition)
(http://www.memoryexpress.com/Products/MX51623)
Graphics card: MSI GTX 980 Gaming 4G
(http://www.newegg.ca/Product/Product.aspx?Item=N82E16814127834&cm_re=gtx_980-_-14-127-834-_-Product)
Possibly a new monitor(Using duo SyncMaster SA300 21.5' monitors but want something bigger)
This is where it gets tricky. I want to experiment with custom water cooling.(Matching the case with red tubing and maybe red graphics card backplate)
However, given the spec I have set up right now, should I not bother with it and just go with standard liquid cooling set up?
There is the refurbished deal from newegg for Corsair Hydro H100i right now.(should I just take this deal?)
What would be the advantage of going custom water cooling over the standard liquid cooling system?
https://linustechtips.com/topic/245055-possible-system-upgrade-routes/
