Hello there, I am new here in this forum and I'm going to build my new gaming rig in a few days. I'm here to check with you guys if my build is okay and if there is any compatibility issues. I will also list down the games that I'll be playing just in case you guys needed. Guidance and advices will be appreicated.
Motherboard : Asus H97-Pro Gamer
CPU : Intel i5-4690
GPU : MSI GTX 970 Gaming 4G
RAM : Corsair Vengeance 1600Mhz (4GB x 2) 8GB
HDD : WD Caviar Blue 1TB SATA3 Harddisk
Case : Cooler Master N300 with Window
PSU : Cooler Master G750M
OS : Windows 8.1 OEM
Others : Asus PCE-N15 (I need this for WiFi)
Games :
-Battlefield 4
-Borderlands : The Pre-Sequel
-League Of Legends
Many more.
1. Budget & Location
SGD 1700, Singapore
2. Aim
Gaming, watching videos, web browsing.
3. Monitors
Either 1 or 2.
Samsung 24” S24D300H 1920 x 1080
4. Peripherals
Corsair K70 RGB
5. Why are you upgrading?
I'm not upgrading, I'm building a new rig.
Can you guys check if my build is okay and has no compatibility issues ?
Thanks in advance.
EDIT : Oh yeah, can you guys also help to check if my build needs some additional cooling ? (Liquid cooling is out of the option due to budget issues)
EDIT : Btw guys, can my build run games with Max settings and Physx Effects ?
https://linustechtips.com/topic/244950-help-needed-pc-build/
Build looks great, and that board is too pretty to not be brought to the US :)
And cooling is no issue, the Intel Stock Cooler should handle the CPU fine.
https://linustechtips.com/topic/244950-help-needed-pc-build/#findComment-3362602
CPU: AMD Ryzen 7 3800X GPU: ASUS Strix Radeon R7 5700 XT OC Edition Motherboard: ASUS Crosshair VIII Hero RAM: G.Skill Trident Z DDR4-3200 CL14 SSD: 2x Samsung 970 EVO Plus 1TB PSU: Corsair AX860 Cooling: NZXT Kraken X72 Case: Corsair Crystal Series 570X Mirror Black Display: BenQ XL2420Z  Keyboard: Corsair K95 RGB Cherry MX Blue Mouse: Logitech G502 Proteus Spectrum Audio: Logitech G633 Artemis Spectrum
https://linustechtips.com/topic/244950-help-needed-pc-build/#findComment-3362606
Looks good, maybe grab a Hyper 212 Evo and an SSD (EDIT: if you can squeeze it into the unspecified budget)?
Maybe downsize the psu to save money
Corsair 350D - ASUS Maximus V Gene - Intel 3770K @ 4.6Ghz - Corsair H100i - G-skill Trident X 2666Mhz 4x4Gb - 2 x EVGA GTX 680 Classified 4Gb @ 1250Mhz - Corsair 860i - 2 x Samsung 840 Pro 240GB (Raid 0)
https://linustechtips.com/topic/244950-help-needed-pc-build/#findComment-3362610
your wifi card doesn´t support windows 8 http://www.asus.com/Networking/PCEN15/specifications/
maybe they didn´t update their website and this card supports win 8
Then may I ask if there's a difference between Windows 7 and 8 in terms of gaming performance ?
https://linustechtips.com/topic/244950-help-needed-pc-build/#findComment-3362639
Yes there is, but minimal(win8 is faster). I would go for Windows 8.1, because it´ll be longer supported.
Ps: I search in the asus website for you a bit and found out that windows 8 drivers are aviable for your wifi card.
https://linustechtips.com/topic/244950-help-needed-pc-build/#findComment-3362670
So, I can actually put in the WiFi card without any issues and it's compatible ?
https://linustechtips.com/topic/244950-help-needed-pc-build/#findComment-3362673
Praise be tomshardware!
Singapore
Fullwell
CH Computer <--- Geared toward overclockers
Chamoxa
If you're going to get a non-K Intel Processor, perhaps consider getting a Xeon? If not you can in fact overclock on the H97 Pro Gaming with a bios update, and should therefore get the 4690k. The Cooler Master N300 has support for the Cooler Master Seidon 240m cooler in the right panel, something to consider getting.
https://linustechtips.com/topic/244950-help-needed-pc-build/#findComment-3362907
Where would you be buying these parts?
https://linustechtips.com/topic/244950-help-needed-pc-build/#findComment-3370987
