H
Go to solution Solved by Robert Lamb,
Yes
Have you connected the cards with a SLI bridge?
https://linustechtips.com/topic/244788-h/#findComment-3359982
this might sound stupid but is the sli bridge on properly?
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/244788-h/#findComment-3359996
Do you have something like a sound card, wireless card, raid card, or some other expansion card plugged into one of your pcie x16 slots?  If so try putting it into one of the pcie x1 slots and see if that works.  You could be eating up too many of the pcie lanes that are dedicated on the CPU.
https://linustechtips.com/topic/244788-h/#findComment-3362324
Take a pic of what you can see.
https://linustechtips.com/topic/244788-h/#findComment-3362675
A pic of what you see on the control panel would help.
https://linustechtips.com/topic/244788-h/#findComment-3365766
