Hi! I want to share this guide that I found in overclock.net (original here: http://www.overclock.net/t/1150443/how-to-remove-your-nvidia-gpu-drivers) Because this is the only thing that worked for me.
I was having random stutters and inconsistent GPU Load in a lot of games. I installed 344.48, went back to 344.11 but nothing helped.
That guide helped.
If you're too lazy to click the link I will quote it here, but I will add some things that I consider important (anyways you're not forced to do what I suggest), the things I added are in italic and underlined, so you decide if you do that steps or not:
Remeber: READ EVERYTHING BEFORE DOING SOMETHING.
Remove Drivers:
1. Access Add/Remove Programs via the Windows Control Panel
2. Uninstall any GPU Monitoring/Overclocking Software (MSI Afterburner, Rivatuner Statistics Server, EVGA PrecisionX) And select "NO" when it asks you to keep your configuration (you want a clean system), reboot every time you uninstall a program (if you uninstall Afterburner, reboot, then uninstall RTSS and so, this is for safety)
3. Remove Any Nvidia Associated Software (like in step 2., reboot after you uninstalled a program, and uninstall one program at a time, I suggest you to be the Driver the last thing you uninstall).
4. Reboot after the uninstall process has completed
Remove left over files/folders:
1. Access Folder Options from Windows Control Panel
2. Click the view tab and select “Show hidden files/ folders and drives (Apply Settings)
3. Access Drive “C” (Or wherever your OS is installed)
4. Delete the folder named “NVIDIA”
5. Go to “Program Files” and delete all NVIDIA associated folders
6. Go to “Program Files (x86)” and delete all NVIDIA associated folders
7. Go to “ProgramData” and delete all NVIDIA associated folders
8. Go to “Users\YourUserName\AppData\Local” and delete all NVIDIA associated folders
9. Go to “Users\YourUserName\AppData\Roaming” and delete all NVIDIA associated folders
10. Just in case, reboot, it wont hurt.
Remove left over registry entries:
1. Access ‘Regedit’ (This can be found in Administrative Tools or by Windows Search)
Please Note: We will be using the left side panel within ‘regedit’ during this tutorial
2. Click “HKEY_CURRENT_USER” and extend the folder
3. Click “Software” and extend the folder
4. Delete NVIDIA associated folders
5. Click “HKEY_LOCAL_MACHINE” and extend the folder
6. Click “SOFTWARE” and extend the folder
7. Delete NVIDIA associated folders
8. Click “Wow6432Node” and extend the folder
9. Delete NVIDIA associated folders
10. Click “HKEY_USERS” and extend the folder
11. Click “.DEFAULT” and extend the folder
12. Click “Software” and extend the folder
13. Delete NVIDIA associated folders
14. Click “S-1-5-18” and extend the folder
15. Click “Software” and extend the folder
16. Delete NVIDIA associated folders
17. Feel free to check the remaining “S-1-5” / “Software” folders for NVIDIA folders (and remove them)
18. Close ‘regedit’ and empty your recycle bin, followed by a reboot
Installing the new Driver! (the next steps are suggestions by me, they're not taken from the original guide, so follow them if you want, it worked for me)
1. Download your drivers (don't install them yet).
2. Boot into safe mode, and install JUST THE DRIVER, uncheck 3D Vision, GeForce Experience, HD Audio, PhysX, everything, just leave the Driver. (You can install 3D Vision, PhysX, GF Experience and the HD Audio later). Also, check the "Clean Install" option, just in case, it's for safety, it won't hurt.
3. Boot normaly, check if everything is all right and then install all your stuff
Just as the guy in the guide, do this at your own risk. I'm not going to be responsible if you threw marshmallows to the GPU while installing the Driver and you ended up killing your loved card, or if you have bad luck and your computer ended up hating you. Like I said
You may say: "Wow, this guy is just plain stupid, it's better to use a Driver Sweeper".
I wouldn't use it, for safety, that kind of software (like CCleaner) can delete important system files (check this: http://answers.microsoft.com/en-us/windows/forum/windows_8-performance/is-ccleaner-safe-to-useplz-be-brief/8c156909-d7f8-4605-af75-4cd60e46a2f5 ). With this guide you're only deleting Nvidia stuff in the registry, nothing else.
I hope it helps. If you don't trust me, check the original guide, he has a lot of positive feedback (including me).
As far as I know, it should also work if you want to change from Nvidia to AMD, this basically deletes any trace of the driver.
https://linustechtips.com/topic/244282-a-guide-for-uninstalling-drivers-nvidia/
thanks for this! I will be doing this soon. :)
(I haven't logged in in years, I have to update this)
My PC Spec:
CPU: Intel i7-8700k @ 3.7GHz, Motherboard: , Memory: 16gb , Storage: , Storage: Crucial BX100 250GB, Storage: Seagate Barracuda 3TB 3.5" 7200RPM, Video Card: EVGA GeForce GTX 970 SC(x2), Case: Corsair C70 Green, Power Supply: EVGA SuperNOVA NEX750G GOLD, Operating System: Windows 8.1, CPU Cooler: CORSAIR Hydro Series H100, Optical Drive: LG Internal Super Multi Drive
  • 3 weeks later...
Haha :P This is useful if you can't format or make a backup of everything.
Also installing updates again is a PITA
Would this damage your computer? :o
I destroy my enemies when I make them my friends.
~Abraham Lincoln
In times when we are on the brink of destruction, war, and loosing ourselves, let's remember a basic fundamental element of love, forgiveness, and understanding; God bless!
I don't think it's possible, is an optional step, so you leave a clean system, that's it. If you don't want to uninstall your programs it's ok, I don't think that it can affect the driver cleaning process, I do it so I don't leave any traces of my GPU.
