How does an H110 work?
I know I've been posting a lot of stuff in the past little while but it is because I am about to make a possible $330.00 order on Amazon. I just want to know how an H110 liquid cooler works. I just plug it in and it works right? I don't need to buy anything else?
Correct me if I'm wrong, it has a radiator with fans on it that transfer heat through water and the waterblock is what cools the processor?
Yeah, the pump on the water blocker pumps the water through the pipes and radiator. When the water goes through the water block it picks up the heat from the cpu. Then what water travels through the radiator where the fans effectively cool down the water so that it cab go back to the CPU and pick up some more heat. And yeah All you have to do is plug it in really.
