i just got a raspberry pi b + and i installed noobs gone to put power in and hdmi and nothing the pwr and activity lights are on but no flickering there just on im on a 800ma power supply, but i  think this could be a problem! on the tv it just says no signal help?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/244167-raspberry-pi-b-help/
800ma is enough...
although on the box it says between 1500-ma and 2000ma
}else{
https://linustechtips.com/topic/244167-raspberry-pi-b-help/#findComment-3349027
Do you have a power brick that supplies more current? And also make sure your SD card is inserted all the way.
https://linustechtips.com/topic/244167-raspberry-pi-b-help/#findComment-3353368
Your English.  What he quoted was entirely too incoherent for a fourteen-year-old in the UK.
That is actually quite offensive. For all you know I could be dislexic, but what do you know? Just because I was on my friends phone and was in a rush to get it working, does not mean I'm a incoherent fourteen year old child. If you decide to critise me then you should be perfect!! And finially what does it matter if I'm from the uk? What can others not write in "coherent" English?
}else{
https://linustechtips.com/topic/244167-raspberry-pi-b-help/#findComment-3365823
If you're 'rushing to get it working,' and can't take the time to at least punctuate a sentence (even on a phone) when you're asking for help, you probably shouldn't expect a very serious response...
Are you sure you're on the right input on the TV? Are you sure you extracted the n00bs files to the SD card, and didn't just copy the .zip file?
https://linustechtips.com/topic/244167-raspberry-pi-b-help/#findComment-3366039
Got it fixed, I was using the wrong format it has to be FAT32 and I just wish people would stop critisizing me i don't have a great deal of self confidence and people making me feel inferior doesn't help!
}else{
https://linustechtips.com/topic/244167-raspberry-pi-b-help/#findComment-3366756
So you're offended.  Okay.
If you'd notice, I didn't call you an incoherent fourteen year old, I called what you wrote incoherent.   But hey...  we all make mistakes, the important thing is to learn from them, right?
https://linustechtips.com/topic/244167-raspberry-pi-b-help/#findComment-3368551
