Overheating?
By
Rockstar4007
in Graphics Cards
in Graphics Cards
Solved by VincentiusIV,
70 degrees is fairly normal. It wont damage the card. The max temp is around 90 degrees, and at 100 degrees the computer will shut itself down to prevent any damage.
If that happens though, RMA the card.
But in your case, you are more then fine. Your R7 260X is not overheating.
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
2
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8
play_circle_filled
Latest From ShortCircuit:
