Simple fan-related question
I ordered 2 different type of cougar fans:
http://www.amazon.co.uk/gp/product/B0050TRLK8?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s01
http://www.amazon.co.uk/gp/product/B0050TRLGW?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s01
One is 120mm the other is 140mm.
Both come with a 3 to 4 pin adapter.
Only the 140mm comes with a fan speed control cable.
How does the fan speed control cable work? Does it run the fan on minimum RPM?
How does the 3 to 4 pin adapter work/where do you insert it into?
I'm a newbie, first build, know little about the type of adapters.
the 4 pin looks like a molex adapter - dunno what that is either. I was under the impression the 4 pin would just be the 3 pin but with one more pin - not a different adapter entirely.
https://linustechtips.com/topic/243999-simple-fan-related-question/
The fan speed control cable reduces the speed of the fan down to 700rpm.
Yes, that's a molex adapter that allows you to attach the fan directly to the psu if you don't have anywhere else to plug the fan.
The actual speed control cable is just a cable with a resistor soldered in line, lowering the voltage to the fan making it soon slower.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
