GTX 980 Reference vs Aftermarket Coolers
So yeah, pretty much I'm looking to buy a 980. Now, I've found this card http://www.overclockers.co.uk/showproduct.php?prodid=GX-038-IN&groupid=701&catid=1914&subcat=1812 which is a reference 980 for around 410 GBP. Could someone please tell me how the noise levels are/performance levels, and what would benefit me if I were to get an aftermarket cooler, such as a twinfrozer, which is 40 GBP more.
Thanks, Miles
The general picture I've drawn from checking out benchmarks is this:
Temps: stock cooler - 80 to 85 degrees under load (chance of throttling), aftermarket coolers - 65 to 75 degrees under load (usually no throttling).
Noise: stock cooler - 45 to 50 dBA, after market coolers - 35 to 40 dBA
If you're fussy about heat and noise and have a good airflow setup in your system an aftermarket cooler is the way to go. But it's not like the stock cooler can't and won't do the job it was designed to do which is keep the GPU's components cool.
