enough power?
Go to solution Solved by xnoobftw,
Would my Gigabyte Windforce 7870 have enough grunt to power a 24 or 27 inch 144hz monitor? Suggestions for 1440 and 1080 monitors would really be appreciated also.
Thanks.
It depends on the games you play. It only gets ard 65fps in bf3 so mehhhh nope. http://www.tomshardware.com/forum/386076-33-7870-1080p
Asus vg248qe is a good choice! (1080p 144hz)
Thanks.
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/243247-enough-power/#findComment-3331898
