Hey guys! I plan on updating my hardware early next year whenever tax season is upon us. My question is, will my hardware be ok to power the GTX 970 I just ordered? I decided to buy the Gigabyte GTX 970 G1 video card while it was in stock this last week. Anyway, my hardware is as follows: Xeon W3520 (i7 920), MSI X58 Pro-E motherboard, 6gbs Corsair XM3 1333 MHz. I know my power supply is plenty, but I'm concerned with how much my hardware will potentially bottleneck this gpu. I currently have this cpu overclocked at 3.5ghz but look to push it to around 4ghz or so to help alleviate any potential strains. Do I even need to do this? Any and all suggestions are greatly appreciated! Thanks!
https://linustechtips.com/topic/242854-will-my-hardware-be-enough/
there will be no bottleneck sir
CPU:  i7 5820k  @4.0Ghz Cooler: Thermaltake Nic C5 Motherboard: MSI X99A SLI PLUS  Ram: 8 gb @2133Mhz GPU: Gigabyte GTX 970 G1 @1560  Case: Proprietary Sun Ultra 24  Storage: HyperX 120gb & 1 TB WD Green PSU: Cooler Master 550w
Awesome! Thanks for all of the responses! You guys are quick! When I go to upgrade, will an i5 be ok for a dual gpu setup, or would it be about the same as what I currently have?
a core i5 haswell is okay for most games at 1080P with dual GTX 970, of course the CPU will be the weakest link in some instances but overall it should do fine...but by the time you'll perform this upgrade my guess is that some newer multi-threaded games and console ports will be out and those will make great use of more CPU threads so you might want to consider a core i7 at this point...but who knows.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Right on. I was just looking up the Xeon X5650. If I can snag one for $60 would that be a better upgrade than a whole new setup? It's a 6 core cpu that apparently overclocks like a champ. I figure a chip like that and a SSD would be a nice addition that could hold me over for a while. Thoughts?
you might be fine but try to overclock your ram to 1600mhz or 1866
PC : | CPU: Intel 4790K | COOLER: Corsair H105 w/ JetFlo's Push/Pull | MOBO: EVGA Z97 Classified | GPU: EVGA FTW 4GB GTX 970 X2 | RAM: Kingston HyperX Beast 1866Mhz 32GB | CASE: HAF Stacker 945 | PSU: Corsair AX1500i | DISPLAY: Asus MX299Q | SSD: 2 X Corsair Neutron GTX 480 GB in RAID0 | mSATA SSD: Samsung 840 EVO 500 GB | HDD: 4 X Western Digital RED 4 TB in JBOD |
RAM speed won't affect gaming performance when using a dedicated graphics card, this has been proved over and over again it would be a waste of time, 800mhz would be plenty for gaming...1333mhz is totally fine:
All games aren't programmed the way Metro is.
i've tested sooo many games on my own system to know it won't affect performance...the one that was making the biggest difference is watchdogs and even then it was within 2-3 FPS improvement to go from 800mhz to 1866mhz.
heck, when you think about it...CPU performance nearly impact framerates in most games...how in the world could RAM make a difference.
''it was within 2-3 FPS improvement to go from 800mhz to 1866mhz'' ''how in the world could RAM make a difference'' You brought it up here, not me.
you've just suggested the OP should try to overclock his 1333mhz RAM or am i high?!
Krytopsy
Member
  • photo-thumb-146609.jpg?_r=1413000499
  • Member
  • 712 posts
Posted 14 minutes ago
