RMA Question
Go to solution Solved by MegaDave91,
The way you received it is generally how they expect you to return it as well.
I'm not sure why you wouldn't return the cables as well.
Hi all
My PSU recently died, and filed for an RMA and the company said to send it back. Which is fine. My question is: Do i need to return everything that it came with. (ie all of the power cords/cables) or just the main box?
Sorry if this is in the wrong section.
Thanks...
https://linustechtips.com/topic/242545-rma-question/
https://linustechtips.com/topic/242545-rma-question/#findComment-3324052
Each company will vary. When you get the email about their RMA process, it should state what they want sent back to them.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/242545-rma-question/#findComment-3324056
Hi all
Thanks...
Usually it would be everything, however you should contact the manufacturer to check because if you don't need to then why bother
https://linustechtips.com/topic/242545-rma-question/#findComment-3324058
when i rma my asus mobo the only thing i sent wqas the mobo nothing else
Love is patient, love is kind. It does not envy, it does not boast, it is not proud. It does not dishonor others, it is not self-seeking, it is not easily angered, it keeps no record of wrongs. Love does not delight in evil but rejoices with the truth. It always protects, always trusts, always hopes, always perseveres.1 Corinthians 13:4
https://linustechtips.com/topic/242545-rma-question/#findComment-3324065
If it's a modular PSU it would be good to not need to redo all the cable management when you get the new unit.
True, but no one said RMA'ing is pretty. At least he doesn't have to RMA his motherboard.
https://linustechtips.com/topic/242545-rma-question/#findComment-3324066
 Yea that was my main "concern". But its alright, ill suck it up. At least it gives me a chance to redo my non-attempt at cable management.
https://linustechtips.com/topic/242545-rma-question/#findComment-3324096
