Hello everyone! I have a small problem: I can't use any of the combinations Alt+1,2,3,4,5,7,8,9 however it works with alt+6 and alt+a letter or alt +numpad, but I don't know why.
I don't have any programs in the background except AMD CCC and the antivirus(I checked with antivirus turned off,same thing).
All the letters work individually.
Does anyone know why this is happening?
https://linustechtips.com/topic/242452-alt123-key-problem/
try toggling num block.
https://linustechtips.com/topic/242452-alt123-key-problem/#findComment-3322977
What keyboard do you have?
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
https://linustechtips.com/topic/242452-alt123-key-problem/#findComment-3323329
If you are trying to use them all at once, it could be that your keyboard does not support a certain key rollover, so it's a keyboard limitation. If you are trying to press them separately, try shift or fn.
If it is the first thing I mentioned, kindly post the model and make of the keyboard you have so we can tell you the maximum amount of keys that can be pressed at once.
I hope this helps! :)
PC in Profile
https://linustechtips.com/topic/242452-alt123-key-problem/#findComment-3323562
