I will be doing a full roleplay of skyrim and need some mod finding things
is their a mod that explainse death, so you dont just die and respawn it will explain it
a mod that ads ilnesses like colds etc
and a mod that automatically changes seasons
https://linustechtips.com/topic/242031-skyrim-mod-help-find/
Skyrim is a Northern region which does not really go through the traditional seasons.  You can enhance the available seasons but not introduce it in the game AFAIK.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/242031-skyrim-mod-help-find/#findComment-3317544
I'm gonna on a limb here and what you're probably wanting is this.
http://www.nexusmods.com/skyrim/mods/26228/? Realistic needs and Diseases?
Also what Samfisher said is true. Skyrim is a northern region doesn't go through traditional seasons there are mods that may change that but odds are it won't be what you're hoping for. All in all give Nexus a look.
https://linustechtips.com/topic/242031-skyrim-mod-help-find/#findComment-3317588
Frostfall maybe.
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/242031-skyrim-mod-help-find/#findComment-3317646
Umm the 1st one I think there is a mod for.. Try looking through MM0xReviews channel to find it
2nd one, realistic needs and diseases
3rd one isn't really possible, you can change seasons out of game in NMM with things like tropical skyrim, Summer skyrim and things like that but none that automatically change it in game
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/242031-skyrim-mod-help-find/#findComment-3317672
