Hey this is my first build and I have a few questions
My specs
Core - i-7 4790k
Mother Board - Asus Hero Vii
GPU - 2x Asus DCU2OC GTX 760
Power supply - EVGA 750W
Case - Cooler Master Haf-X
RAM - G. Skill Ripjaw X 8GB
CPU Cooler - Nocuta D14
I was just wondering if running dual GPU will help me run games like Skyrim and Shadows of Mordor better then a single.
Is 8GB of ram sufficient?
https://linustechtips.com/topic/241872-my-first-build/
The thing is I'm on a budget. I can get 2 760 for $400
970 is cheaper then that. it's around 320$ if you wait a little awhile
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/241872-my-first-build/#findComment-3315168
