Is threre a danger with 6pin-8pin adapters?
Solved by Maverik5124,
pci-e slot: 75w
6 pin: 75w
8 pin: 150w
I don't approve of 6 to 8 pin adapters
Yes this is the atx specification. But the specification for the connectors themselves are way higher so there should not be a problem when using an adapter. I think this kind of sucks though because if they would just use the specifications by the manufacturer of the connectors then we could get away with using just one connector on most graphic cards
