I have a 280L coming on Thursday. My case is an NZXT. S340. I currently have tow Fractal 140mm Silent Series fans on the front of the case. I am going to do push pull with the radiator. Should I push with the CM and pull with the Fractal or the other way around? Thanks.
https://linustechtips.com/topic/240803-cooler-master-nepton-280l-push-pull/
Use the CM fans as push, and the other ones as pull.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
I'm looking at getting this cooler. This is an interesting idea.
If I'm understanding this you can place one set of fans on one side and another set of fans on the other?
Do you need to buy special screws? *longer
Play the greatest game ever. TF2. http://www.teamfortress.com/
I wouldn't do it.
1. CM AIO's come with fans good and quiet enough to efficiently dissipate the heat from their rads.
2. You won't see any significant performance increase by running push/pull on such a thin and low fpi rad, it's just take up more space
3. If you're doing push/pull, it has to be done with 2 sets of identical fans.
Bert & Ernie before squirting spermie.
No, there are screws holes on both sides of the radiator.
