Power supply about R9 270X + FX-8350
Diskey
I'm fairly new at this forum, created an account because I'm being crazy about this whole power supply thing.
I already have an A6-5400K running but maybe after 3 days as of writing this, a box from a relative overseas will arrive. I'm currently confused if my current 500W Zalman ZM500-GS is enough to run this:
MOBO: Gigabyte 970A-UD3P
CPU: FX-8350
GPU: Sapphire Dual-X R9 270X
2 SSD's + One 2.5 HDD (don't ask) + One 3.5 HDD
Any inputs will help.
Thank you very much. :)
i think so, but it will now leave much power so spare, but it will
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
Which 500W? It will likely be fine but better to make sure so you're safe and not sorry.
"Rawr XD"
yes but i would make sure it is a decent unit otherwise rails and shit might blow it up
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
I've built three systems close to that spec this last year timeframe using lesser than what I'd choose as acceptable PSU's. All being 500w (Customers went against advice)
Yet all three systems so far have had no issues as of yet, two of them are over 9 months old, one is 3 months old. (I see these people regulary)
I'd recommend usually 500-550w for such a system if they don't usually upgrade or game often,.....from a reputable company (Zalman I dunno, CPU coolers yes, but PSU's...)
2x 8350 + 270x systems & a FX-6300 + 280x
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
A quality 500W PSU is more than enough. Not sure about that zalman unit.
If you're going to buy that unit, don't! Go for a seasonic 550RM.
Thank you for the inputs, I really appreciate it. Maybe for the meantime, I'll stick to my current psu and maybe go for Seasonic PSU's because it is the only psu that is readily available in shops near my place. MOBA (Dota2,HoN,etc.) and spotify is my routine. Thanks again. Good day to you all.
well I do remember building some units with a zalman 500w psu. since it was so cheap here. I haven't seen those rigs get returned yet for warranty. that could mean the zalman psu could be decent or they just bought a new one or the customers are just happy and lucky they got a decent one.
Live your life like a dream.
Additional question: is this review site good? I've been reading and I only found this about my current PSU. If I'm not allowed to link something, I'm really sorry and I'll take it down as soon as anybody will tell me.
http://uk.hardware.info/reviews/4107/3/zalman-zm500-gs--zm500-gt-psu-review-specifications
can't really remember but I think the one I wrote about is the gt ones. since I don't have any psu that's not 80plus rated at shop.
