My build has been pushed back to the February so I decided to make the budget higher for the build.
The build has to be a $750 build max WITH a IPS monitor included because Tn panels are a little eh in my opinion and no APU's or Dual core processors like i3 or pentium anniversary.I live in the US by the way.
https://linustechtips.com/topic/240727-my-first-build/
You're going to only have around $500 after the monitor, and with that budget you will have to go with low end components.
It would be best to go with something such as the pentium g3258 and a GTX 750ti or R9 270.
https://linustechtips.com/topic/240727-my-first-build/#findComment-3300024
to get a i5 in this system you would really need to cheap out on a few other things. but i'll see if it can be done.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/240727-my-first-build/#findComment-3300034
This forum is for the build log not planning and advice of what to get. Sorry not trying to be an ass.
https://linustechtips.com/topic/240727-my-first-build/#findComment-3300065
http://pcpartpicker.com/p/fpJY23
Check that system build, it costs only more 188$ than your 750$ budget.
It has a IPS monitor and a Intel Core i5-4690K. :P
System 1: Thermaltake Element Q - Thermaltake 220W SFX - Asus AT5IONT-I mini-ITX - Intel® Atom™ D525 onboard 1.8GHz Dual-Core HT - Integrated NVIDIA® ION™ - 2x 2GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
System 2: Thermaltake Element Q - Thermaltake 220W SFX - Asus E2KM1I-DELUXE mini-ITX - AMD E2-2000 onboard 1.75GHz Dual-Core - Integrated AMD® Radeon HD 7340 - 2x 4GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
Building: Bitfenix Prodigy Black - Corsair AX860i - Asus Maximus VII Impact - Corsair Hydro Series H100i - Intel® Core™ i7 4790K - Asus Matrix Platinum GTX 980 4GB - Corsair 16GB Dominator Platinum 2x 8GB DDR3 2400MHz CL10 - Samsung 1TB EVO 840 Series
https://linustechtips.com/topic/240727-my-first-build/#findComment-3300213
you don't need to buy an 250$ monitor.
I will edit this as soon as i got a build :>
http://pcpartpicker.com/p/MwXTjX
You have 25$ left, you may want to change the case or mobo. I took an M-ATX mobo for if you want to change your case after a year or so.
Edited by Antibull
https://linustechtips.com/topic/240727-my-first-build/#findComment-3305000
He said it has to be IPS, and decent quality IPS monitors are not cheap.
https://linustechtips.com/topic/240727-my-first-build/#findComment-3306435
