Hey guys i'm building a gaming pc in about half a year, my budget is around $1000 (Give or take $200 extra). The question is what graphics card and/or other parts do you recommend?
Link: http://pcpartpicker.com/p/82qTjX
I have a budget for my graphics card and power supply of around $300 (Give or take $200) I will be buying 2
ASUS VG248QE monitors to go along with the build and a new keyboard and mouse.
So what parts do you recommend me purchasing? Thanks in advance, sorry for the poor sentence structure :D
https://linustechtips.com/topic/240617-first-build-need-help-d/
Dead link
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298483
I cant see that link so... this is my suggestion for that price range:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.96 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.98 @ OutletPC)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard ($127.98 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($81.99 @ Amazon)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($79.79 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($53.95 @ Amazon)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card ($349.99 @ NCIX US)
Case: NZXT Source 210 Window ATX Mid Tower Case ($51.98 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($44.99 @ Newegg)
Total: $1049.61
Generated by PCPartPicker 2014-10-28 16:44 EDT-0400
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298495
Dead link
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298496
Total: $1049.61
yea that one looks good
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298502
Ok heres the working link, I also wanted to add I don't need a SSD or a Hard drive. http://pcpartpicker.com/p/82qTjX
Well... yeah, you should go with my build instead... also a 120GB SSD for the OS is something I definitely recommend at any build around 1000$ or more. It will speed up your system alot.
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298544
this
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298548
Did you actually read the reply I posted I have a HDD and SSD.
I swear some people on this site are reading impaired (shh)
Don't get AMD for gaming, most games today use 4 cores or less, and an i5 is the currently the best CPU for gaming.
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298589
Oh... you posted that you dont need a SSD and I stop reading from there because alot of people saying that and go with a build without a SSD... If you say your already have SSD and HDD it will be a different matter. Either way just remove the SSD and HDD from the build I gave you~
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298598
Try this one :)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($362.92 @ Amazon)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Total: $984.34
Generated by PCPartPicker 2014-10-28 16:56 EDT-0400
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298613
this also the fx cores are extremely underpowered compared to any intel from the past 5 years
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298618
Who said I'll be gaming? I'm using this build... Yes for gaming but also for light 3D rendering. I have a system thats worth alot more but I have had the urge to build one myself.
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298628
Slightly updated better ram lower psu but with ssd
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($127.99 @ Newegg)
Storage: Kingston HyperX 3K 120GB 2.5" Solid State Drive  ($79.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($81.98 @ Newegg)
Total: $1043.38
Generated by PCPartPicker 2014-10-28 17:00 EDT-0400
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298650
FX will be better then an i5 in things that can actually use all 8 cores, since each i5 core isn't necessarily twice as powerful as each FX core.
Gaming won't benefit from the extra cores though, just things like photo/video editing, 3D rendering, etc
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298656
You did look at your first post it says you are building a gaming pc
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298658
The first sentence of the OP says gaming PC. Light 3D rendering will still be perfectly fine with an i5, the performance boost an FX will give in rendering doesn't outweigh the performance loss in games.
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298661
True in rendering the 8350-8320 are a much better deal
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298663
... you should read this thread before making a thread... http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
Anyway if it just light editing a i5 4690k is good too, and if whatever you use can really use multiple cores then a FX 8370 might not be a bad choice, still it's not good for gaming though. But for Mobo I'd say you better go with ASUS/MSI/Gigabyte mobi instead of ASRock. And the H100i is quite old so how about H220-X or Kraken X61 or H110 instead?
https://linustechtips.com/topic/240617-first-build-need-help-d/#findComment-3298671
