970 Coil Whine Problems
Go to solution Solved by Archangel1994,
GIgabyte G1 Gaming GTX 970 here. Absolutely zero coil whine <3
So online I have heard many people complain about coil whine on the MSI and ASUS GTX 970s. I was considering these two because of their ability to passively cool themselves. I wanted to know if anyone who owns a 970 could tell me how bad the coil whine is (if any)?
SYSTEM SPECS
i7 4790k | LTT Edition Noctua NH-U12S | Gigabyte Z97-SOC Force | 16GB Crucial Ballistix Tactical Tracer DDR3 | 120GB Samsung 850 EVO | 1TB Western Digital Caviar Blue | NVIDIA GTX 980ti | H440 Orange | EVGA 650B3 PSU
https://linustechtips.com/topic/240512-970-coil-whine-problems/
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/240512-970-coil-whine-problems/#findComment-3297224
I
How quiet is it.
SYSTEM SPECS
https://linustechtips.com/topic/240512-970-coil-whine-problems/#findComment-3297263
I
How quiet is it.
Can tune it up to 70% and still not hear it that much. It's pretty damn quiet
https://linustechtips.com/topic/240512-970-coil-whine-problems/#findComment-3297273
OK ill look into that one, also do you think you could set the fan profile to become passively cooled at idle and under a light load
SYSTEM SPECS
https://linustechtips.com/topic/240512-970-coil-whine-problems/#findComment-3297288
EVGA always have coil whine I had two 680 in sli two years ago & they were horrible but I'm surprised that they haven't solved this problem yet
I5 3570K@ 4.4 - GIGABYTE Z77- Kingston 8G 2400 RAM - MSI GTX980 - HAF-X - 27'' ROG SWIFT + 32'' LG IPS - OCZ 250G SSD + WD 4TB HDD - ASUS XONAR DX -Noctua NH-D14
https://linustechtips.com/topic/240512-970-coil-whine-problems/#findComment-3297295
Nope, fan speed does not go lower than approximately 40%. However it's pretty much silent at that percentage.
https://linustechtips.com/topic/240512-970-coil-whine-problems/#findComment-3297296
You can't solve coil whine, it's luck of the draw
https://linustechtips.com/topic/240512-970-coil-whine-problems/#findComment-3297298
My Gigabyte G1 970 have coil whine, not too bad but it is audible.
Case: CM Storm Scout2<>CPU: i7 3770K<>Cooler: Thermaltake NIC C5<>GPU: Gigabyte GTX 970) Sound: Sound Blaster Z<>MB: Asrock Z68 Gen3<>RAM: Kingston HyperX 2X4 2133mhz<>SSD: Crucial M500 240GB<>HDD: Segate Barracuda 2TB 16mb<>PSU: EVGA SuperNova 750B Modular 61A
https://linustechtips.com/topic/240512-970-coil-whine-problems/#findComment-3297895
