The bios. YOu can set your CPU fan speeds there
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/240492-crazy-cpu-fan-speeds/#findComment-3296978
Are you running an AMD stock cooler? They run at 3000-5000rpm (sometimes more) and are rated at that because they're little 80mm fans that have to cool that ridiculous 125W TDP. Mine does exactly the same, but they're rated at it so it won't blow up or anything. Just save up for a decent cooler.
https://linustechtips.com/topic/240492-crazy-cpu-fan-speeds/#findComment-3297132
