Old Hard drive help
Go to solution Solved by Levent,
you are lucky that drive is SATA you can simply connect it to your sata port and connect sata power to check its content
Hi all, Im setting up a new windows 8 rig with an SSD hard drive. I recently found my old Raptor X that has windows XP installed on it. Is there any way I can look around my old hard drive and see if there are any files I want, back them up and then wipe the drive and include it into my new rig?
AMD FX-8350 @ 4.7Ghz when gaming | MSI 990FXA-GD80 v2 | Swiftech H220 | Sapphire Radeon HD 7950  +  XFX Radeon 7950 | 8 Gigs of Crucial Ballistix Tracers | 140 GB Raptor X | 1 TB WD Blue | 250 GB Samsung Pro SSD | 120 GB Samsung SSD | 750 Watt Antec HCG PSU | Corsair C70 Mil Green
https://linustechtips.com/topic/24024-old-hard-drive-help/
https://linustechtips.com/topic/24024-old-hard-drive-help/#findComment-304377
thanks for the reply!
https://linustechtips.com/topic/24024-old-hard-drive-help/#findComment-304527
