Sorry if I'm not abiding by a rule, I'm quite new. I currently have a GTX 560 2GB Special Edition by EVGA (the one with the yellow stripe, classified?) and I'm looking to upgrade. My budget MUST NOT exceed $200, I;m not afraid of getting a used card, I'm looking for other people's opinions on what I should do? My current setup is: i7-3770(non-k), 16gb 1600MHz ram, 120gb SSD, Corsair HX750
https://linustechtips.com/topic/240190-upgrade-help/
http://pcpartpicker.com/part/powercolor-video-card-axr92852gbd5tdhe
This should be good for you, buying used is sometimes okay but with amd cards usually the used ones were ones previously used for coin mining so their lifespan is severely shortened so you should stay away from those. Also welcome to the forum :D
CP: Ryzen 7 2700x | Motherboard AsRock B450M | RAM 32GB Corsair ddr4 | GPU EVGA (RIP) 1070ti | Case Corsair Vengeance C-70 Black | Storage 512gb Samsung NVME ssd | PSU EVGA 850w Platinum | Display Asus PB258Q 1440p
| Cooling Noctua NH D15 | Keyboard Cooler master mechanical kb with blue switches | Mouse Logitech G502 | Sound Beyerdynamic DT 990
| Laptop Maingear Vector Pro 2 (Ryzen 9 6900xh, Nvidia 3070t, 32gb ram)
https://linustechtips.com/topic/240190-upgrade-help/#findComment-3292949
