Help!! Need to decide how to properly cool the system (water cooling loop is preferred) with enough room to fit some 2 or more fans here and there to provide a bit cooler environment, the parts in this build are;
CPU: AMD FX-8350 4.0GHz 8-Core Processor (Overclocked to 4.7ghz -ESTIMATED-)
MOBO: ASRock 990FX Extreme9 ATX AM3+ Motherboard(Bang for de' Buck)
RAM: Kingston HyperX Beast 16GB (2 x 8GB) DDR3-1866 Memory (Hittin' the sweet spot)
GPU: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card (Custom Bios To Achieve more performance -if necessary-)
OS BOOT DRIVE: Samsung 850 Pro Series 128GB 2.5" Solid State Drive (dedicated boot drive)
STORAGE DRIVE: Seagate Constellation ES.3 1TB 3.5" 7200RPM Internal Hard Drive (dedicated file storage)
CASE: Corsair Air 540 ATX Mid Tower Case (sexy)
PSU: Antec 850W 80+ Platinum Certified Fully-Modular ATX Power Supply (very sexy)
SOUND CARD: Asus Xonar D1 24-bit 192 KHz Sound Card (super sexy)
*Open to suggestions(No I'm not going to switch to intel) and with this motherboard, do i need a wifi card? THANKS GUYS FOR YOUR HELP!! IF ANY PARTS NECESSARY IN MY PC BUILD PLEASE SAY SO!!
P.S. Comment below what you think of the build! THANKS!
https://linustechtips.com/topic/240187-please-help/
That case indeed is sexy.
For cooling I'd suggest the h100i or h105.
Yes you would need a WIFI card, I have the http://www.amazon.com/gp/product/B007GMPZ0A/ref=olp_product_details?ie=UTF8&me= It has given me no trouble so far.
https://linustechtips.com/topic/240187-please-help/#findComment-3292890
you're sinking way to much money on a platform that will bottleneck you gpu regardless of how high you'll overclock that cpu...youd be much better of with a core i5-4460 and a cheap h97 motherboard, this will offer gaming performance the highly overclocked old FX can only dream of...also intel consumes a lot less so you can use the stock cpu cooler ;)
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/240187-please-help/#findComment-3292955
You are overspending on the psu, SSD and HDD. You don't really need a soundcard these days as boards have good on board sound.
Why are you not open to an Intel cpu ?
https://linustechtips.com/topic/240187-please-help/#findComment-3293109
Oh thanks for the iput on the sound card and the intel cpu is because I really am aiming to spend the least amount of money on the cpu because this will be a dedicated gaming rig as i do  have another rig setup for video and photo editing (yes it is intel)
https://linustechtips.com/topic/240187-please-help/#findComment-3299636
Thanks for that I just might consider it based on your analysis :)
https://linustechtips.com/topic/240187-please-help/#findComment-3299642
Thanks for acknologing the sexiness of this case ;3 also awesome! thanks for that wifi card bro!
https://linustechtips.com/topic/240187-please-help/#findComment-3299662
An H105 would do fine, or are you looking for a custom loop?
Also, see if you can squeeze in an SSD. 16GB is a little overkill, you can go to 8GB and use that money for the SSD.
Awesome cooler dude but i was looking for a custom loop to also cool my gpu thanks!
https://linustechtips.com/topic/240187-please-help/#findComment-3299665
Thank you to all of you who have posted so far! I really appreciate it and hope to hear more from you to have more input from all of you and lets keep this discussion going so we can have as many people involved in giving advice as possible so i can hear from all or most of what the community might have to offer! :) thanks again guys hope to hear from you soon and once i get everything together i will begin uploading pictures as the build progresses!!
https://linustechtips.com/topic/240187-please-help/#findComment-3299679
Damn 6 posts in a row? You do know you can quote multiple people in one post, just click multiquote for each post you want to quote, then click "Reply to _ quoted post(s)", or just click quote on each post.
https://linustechtips.com/topic/240187-please-help/#findComment-3299686
LOL MY BAD haha! From now on ill do that so that my posts aren't in a row like so xD
https://linustechtips.com/topic/240187-please-help/#findComment-3299694
It still doesn't make sense to go with an fx8350 over an i5 4690K especially as you have the budget for it.
https://linustechtips.com/topic/240187-please-help/#findComment-3299763
i might consider it
even a locked core i5 and a cheap H81 or H97 motherboard is a better pick in regards to gaming and it won't break the bank...especially when you consider that you'd need a more expensive board on AM3+ and an aftermarket CPU cooler.
This would be my suggestion for budget gaming rig mate:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($184.98 @ SuperBiiz)
Motherboard: MSI Z87-G41 PC Mate ATX LGA1150 Motherboard ($53.00 @ Newegg)
Total: $237.98
Generated by PCPartPicker 2014-10-28 21:01 EDT-0400
https://linustechtips.com/topic/240187-please-help/#findComment-3299963
I honestly am saving a few bucks just to get the same performance and only 5 or so less fps going with AMD over INTEL
depending on the game it will be much more than that most of the time...also its the minimum fps that takes a hit and this is what you notice the most while gaming.
also intel is much more energy efficient, and as mentionned already you are not saving money going amd youll need at least a 85$ mothetboard and a 35$ cpu cooler (at least) which end up costing more than the intel kit i've suggested.
https://linustechtips.com/topic/240187-please-help/#findComment-3300180
i might consider it
This is your current Basket:
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($169.98 @ OutletPC)
Motherboard: ASRock 990FX Extreme9 ATX AM3+ Motherboard  ($154.79 @ Newegg)
Memory: Kingston HyperX Beast 16GB (2 x 8GB) DDR3-1866 Memory  ($172.24 @ TigerDirect)
Storage: Samsung 850 Pro Series 128GB 2.5" Solid State Drive  ($118.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($349.99 @ Amazon)
Case: Corsair Air 540 ATX Mid Tower Case  ($129.99 @ Newegg)
Sound Card: Asus Xonar D1 24-bit 192 KHz Sound Card  ($82.99 @ Newegg)
Total: $1468.94
Generated by PCPartPicker 2014-10-29 09:14 EDT-0400
i5 4690K spec with similar parts:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.96 @ OutletPC)
Motherboard: MSI Z97-Gaming 9 AC ATX LGA1150 Motherboard  ($251.98 @ SuperBiiz)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.97 @ SuperBiiz)
Total: $1414.10
Generated by PCPartPicker 2014-10-29 09:22 EDT-0400
The MSI board has built in wifi.
The Antec psu is very good, but as the 540 case has a separate chamber you won't see it anyway.
The EVGA is one of the best psu's for the price/performance.
The Crucial SSD is very good and is a better choice over the pricey Samsung 850.
The Motherboard has good onboard sound, so I dropped the Soundcard.
You could swap the board for a cheaper one and go with a separate wifi card.
https://linustechtips.com/topic/240187-please-help/#findComment-3303223
Total: $1468.94
Total: $1414.10
This is impressive but, what then would be the best option for custom loop cooling to both cpu, gpu, and if possible the ram?
https://linustechtips.com/topic/240187-please-help/#findComment-3306650
You might be best asking in the water cooling section. I don't have any knowledge on custom loops myself as I have only ever used Air coolers.
If you are watercooling the gpu though, it might be an idea to get an EVGA card as they don't void your warranty (As far as I know) if you remove the cooler. I don't know if Gigabyte or other companies have the same policy.
https://linustechtips.com/topic/240187-please-help/#findComment-3306750
https://linustechtips.com/topic/240187-please-help/#findComment-3306869
why would you wan't to custom loop cool a 3 years old AMD FX 8 core CPU for gaming? do you really can possibly think this is a good idea?
The intel i5 at stock speed under the stock intel heastink will destroy that thing in anything all day long WTH.
https://linustechtips.com/topic/240187-please-help/#findComment-3310324
