this is my code that we have for my homework and i cant figure out how to fix my error message
# Imports
from os import getcwd, chdir, path, mkdir
#add import for randint function
#add import for stdev function from statistics library
def get_inputs():
    '''Gets username and how many integers to generate input by the
    user. Returns both to main.'''
    username = input('Enter username: ')
    how_many = -1
    while (how_many < 100) or (how_many > 1000):
        how_many = int(input('Enter a number from 100 to 1000: '))
    return username, how_many
def create_subdir(subdir):
    '''Create a subdirectory. Does not return a value.
    subdir: a string representation of the subdirectory path.'''
    #Hint: see 'navigating directories examples.py' in Week 7 folder
    # if the path to subdir doesn't exist
        #create the subdirectory
    # otherwise, print message that subdir already exists
def write_rands(how_many, lower, upper, filename):
    '''Write random integers to a file. Does not return a value.
    how_many: the number of integers to write
    lower: lower bound for randint
    upper: upper bound for randint
    filename: file integers are written to'''
    outfile = open(filename, 'w')  # opens file for write
    #Hint: see 'write numbers to file.py' in Week 7 folder
def read_rands(filename):
    '''Read random integers from a file into a list. Returns a list.
    filename: a string variable naming the file to read from'''
    intlst = []  # initalize as empty list
    #Hint: see 'sum numbers from a file.py' in Week 7 folder
    return intlst
def mean(intlst):
    '''Calculate and return the mean.
    intlst: a list of integers'''
    #initialize accumulator variable
    #iterate through each number in intlst
        #add it to accumulator variable
    #get length of intlst and convert to a float; then use
    #to calculate the average
    return average
def median(intlst):
    '''Calculate and return the median. Copies intlst to a new list
    so that it is not reordered by .sort()
    # Create a new copy of intlst to avoid side effects
    # because .sort() mutates the list
    sortlst = intlst[:]
    #sort sortlst with the built-in list sort function
    # Get middle of list
    middle = len(sortlst) // 2  #integer division to get middle of list
    if len(sortlst) % 2 == 0:  # List has even number of elements
        # This puts two 'middle' elements into a new list
        middlelst = [sortlst[middle-1], sortlst[middle]]
        #add call to your mean() function to calculate
        #the average of middlelst
    else:  # List has odd number of elements
        calc_median = sortlst[middle]
    return calc_median
# Can't use the name range, that's a built-in function
def myrange(intlst):
    '''Calculate and return the range.
    #get min of intlist by searching it for the smallest element
    #get max of intlist by searching for largest element
    #calculate range, which is the max element minus the min element
    return calc_range
def std_dev(intlst):
    '''Calculate and return the standard deviation of intlist
    using built-in python function stdev().
    # Use stdev() to calculate standard deviation
    return calc_stdev
def print_results(calc_mean, calc_median, calc_range, calc_stdev):
    '''Prints the results. Does not return a value.
    calc_mean: the calculated mean
    calc_median: the calculated median
    calc_range: the calculated range
    calc_stdev: the calculated standard deviation'''
def main():
    # Initialize constants and variables
    filename = 'stats.txt'
    lower = 27
    upper = 53
    # Request inputs
    username, how_many = get_inputs()
    # Create the subdirectory
    #assign a string to subdir variable that represents a path name that is
    #the subdirectory to create. Hint: see 'navigating directories examples.py'
    #in Week 7 folder
    # Change to the created subdirectory (this must be in main, not a function)
    ### add one python statement to change the directory
    print('current directory', getcwd())
    # Write random integers to file
    # Read random integers and assign to variable intlst
    #add function call to read_rands
    # For testing mean, median, myrange, and std_dev
    # functions. Comment out after testing.
    intlst = [1, 2, 3, 4]
    # Calculations
    calc_mean = mean(intlst)
    calc_median = median(intlst)
    #add function call to myrange
    #add function call to std_dev
    # Output results
main()
thank you for your help
https://linustechtips.com/topic/240043-python-help-with-subdirectorys/
Please use code tags and state what your error message/problem is.
Is it to help you figure out how to implement create_subdir(subdir)? If so the comments are already telling you what to do, and you seem to have some example code you can reference.
