Case front fan rattling.
To my knowledge fans are very accurately5 balanced and its probably easier to replace for 20-40 bucks than try to fix it.
Just look up the size and get a new fan.
(I could be wrong but I think its probably not worth it)
P.S. You could figure out if the blades are hitting anything. or the reason for the rattle.
https://linustechtips.com/topic/239968-case-front-fan-rattling/#findComment-3290401
The fan is rattling but the blades are not hitting anything. Strange? So why is rattling? Can you tell me?
Bearings.
Fan bearings wear out, I end up replacing many of mine every couple of years. Probably just spend $15-20 on a new fan - which will be better that the original anyway.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/239968-case-front-fan-rattling/#findComment-3290461
Most likely the bearings but check the screws are not loose first that could cause rattling aswell but that would mean that most of the screws would have to be loose and shouldnt happen over time.
My Rig : Zotac 780 3GB, i5 4670k, H105, M1211 650W, 8GB 2133mhz vengence pro, Mini R2, 144Hz AOC Gsync Monitor
Accessories : K65, Naos 3200, Superlux 681, Chord CCU1
https://linustechtips.com/topic/239968-case-front-fan-rattling/#findComment-3290479
Why when i remove front panel of case and rattling in front case fan gone? Front case fan is still working ON he just stop rattling when i remove front panel case. Can you explain me why?
Something loose on your front panel. Probably.
https://linustechtips.com/topic/239968-case-front-fan-rattling/#findComment-3298371
Might be the panel rattling, every part of your system that has a moving part is causing the case to vibrate. Since it's an old case the front panel or the optical bay covers may not be as solid as they could be. Apply small amounts of pressure to it in various locations, if the sound stops then find something to act like a shim.
If that doesn't help, it may be front panel cables. If they're built into the panel and not the case then they could be somewhere the aren't intended to be.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/239968-case-front-fan-rattling/#findComment-3298377
I mount again front panel of case and still no rattling. Question . I remove sponge from front panel. It can be because earlier fan was touching sponge from front panel?
Could be, fans don't react well to things touching them while moving. Though that sponge is your air filter so you may see some more dust.
https://linustechtips.com/topic/239968-case-front-fan-rattling/#findComment-3298814
