Upgrade my build? Help please
No its not really struggling, i also don't do much video editing/ rendering. For some reason i thought that maybe the gtx 980 wouldn't perform as well with my cpu.
If the i5 will handle it fine then i am most likely going to save that money and upgrade to 2 new monitors. (not sure which ones yet tho).
Your i5 is fine, dont upgrade it. A GTX 980 isnt a very viable choice since you can get 2 970 at only 100$ more and 2 970 will do much much better than 1 980, especially if you plan to go with 3 monitors setup.
Also, think hard about your monitors setups. To me at least the 3 monitors setup is quite distracting and not useful for gaming (except racing game). But if you have 2 monitors the game cant be run on 2 monitors, it can only run on 1 or 3+ monitors since Nvidia and AMD design Surround and Eyefinity that way (it do make sense since you dont want your crosshair lying between 2 monitors). 2 monitors however is very good for multi tasking, such as playing games on 1 and keep a guide/ youtube/ facebook etc on the other.
