Storage solutions for a laptop
Solved by Captain_WD,
Hello, whilst browsing for a new laptop (non gaming purposes). I had this sudden urge to buy and insert an SSD into it. Problem is though, I dont know how to check or find out if the laptop supports this, how do I find out?
Looking at Acer Aspire E5-511.
Hey Transon,
Your laptop should run any 2.5 inch SSD without any problems so, by all means, go for it.
I could suggest checking out WD Black2 as a dual drive for your laptop. It combines a 120GB SSD with a 1TB HDD in one 2.5 inch enclosure. The advantage of a dual drive over a SSHD is that you have much more SSD space (basically a whole different drive) and you have the choice where to store your data, rather than leaving the drive to decide what to store on the SSD. Here's a link: http://www.wdc.com/en/products/products.aspx?id=1190#Tab2
Otherwise, I would ask the guys here in the forum to recommend a good SSD, depending on your size, price and manufacturer preferences
Captain_WD.
