The RAM will be fine with the cooler, but the cooler will not fit in the case.
Why go for air cooling in such a small case anyways? you might as well just stick a 240mm aio watercooler in it and have a much cleaner look. (It can be mounted on the front)
( @Rx787 follow your threads so you know when people reply! )
https://linustechtips.com/topic/239671-will-it-fit/#findComment-3286313
I second this.
Go for a H105 so you can colour and logo match it to the case ;)
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/239671-will-it-fit/#findComment-3286359
I second this.
That would be good, or the H100i :)
-·- BitFenix Prodigy M (Arctic White) -·- Asus Maximus VII Gene -·- Intel Core i7-4790K -·- Corsair H100i -·- G.Skill Trident X 2133MHz CL9 32GB (4x8GB) -·- Sparkle Calibre GTX580 -·- Samsung 500GB 850 Evo SSD -·- WD Caviar Green 4TB -·- Cooler Master V700 -·- LG 25UM55 21:9 2560x1080 25" -·- Logitech G600 -·-
https://linustechtips.com/topic/239671-will-it-fit/#findComment-3288377
H100is are not that good. They're prone to dieing.
MFW I got one for the PC I'm building :(
https://linustechtips.com/topic/239671-will-it-fit/#findComment-3288575
I got a H100i for my build (below). It leaked over everything and fried the CPU. at least corsair replaced everything and gave me a H105 ;)
https://linustechtips.com/topic/239671-will-it-fit/#findComment-3288599
:blink:
https://linustechtips.com/topic/239671-will-it-fit/#findComment-3289012
:blink:
Here's a Screenshot of the two images I sent off to the Corsair RMA people in the form they sent me. The darker area is where the H100i leaked.
https://linustechtips.com/topic/239671-will-it-fit/#findComment-3289232
-frightening snip-
Eek. I hope it doesn't happen to me  :blink:
#fingerscrossed
https://linustechtips.com/topic/239671-will-it-fit/#findComment-3289970
