UPDATED** Hi! I'm new here and I'm planning on building my own rig soon.  I would like to get some advice from y'all.
1.  Planning on building a $2000 USD gaming rig. Here are the parts that I'm planning on buying.
Case - Corsair Obsidian 350D Mid Tower
PSU - Corsair AX760 760 Watts
Cooler - Corsair H100i Liquid CPU Cooler
Memory - Corsair Vengeance Pro 16GB
SSD - Intel 520 Series 120GB (2 in Raid 0)
SSHD - Seagate Desktop 2TB
MoBo - Asus Maximus VII Gene mATX
Processor - Intel i5-4690K 3.2Ghz
GPU - Asus Strix GTX 970 (2 in SLI)
OS - Windows 8.1 Pro
2.  This is strictly a gaming and homework rig.  I want it to play all upcoming games in medium to high settings.  I won't be doing 3D rendering of sorts just light web design and html coding.
3.  I have 3 monitors already (all the same model) which I plan to use for surround gaming with medium to high resolutions.
4.  I already have keyboards and mouse that I'm accustomed to use.  I also have Windows 8.1 Pro installer.
I hope this helps you all in giving a better advice.
Thank you in advance!
https://linustechtips.com/topic/239407-first-build/
Please use automatic color in your posts!
The build is pretty good, though I'd personally go with 1 240GB SSD.
Also the i5 4690K should be 3.5GHz at stock speeds, not 3.2GHz.
Also for gaming you do not need 16GB of ram, 8GB is plenty.
https://linustechtips.com/topic/239407-first-build/#findComment-3282850
This is far more cost effective that what you proposed:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
CPU Cooler: Cooler Master Seidon 240M 86.2 CFM Liquid CPU Cooler  ($74.99 @ Newegg)
Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard  ($117.98 @ SuperBiiz)
Memory: PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory  ($134.00 @ Amazon)
Storage: PNY XLR8 240GB 2.5" Solid State Drive  ($94.99 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card (2-Way SLI)  ($329.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $1616.12
Generated by PCPartPicker 2014-10-26 14:48 EDT-0400
https://linustechtips.com/topic/239407-first-build/#findComment-3283413
