im building a gaming pc, my first build and i am using an r9 280 will an i5 4440 http://pcpartpicker.com/part/intel-cpu-bx80646i54440 hold it back? also what kind of mobo should i get?
no it will not hold it back also you should get a z97 mobo so you can upgrade to a broadwell i7 or i5 in the future and overclock k skews
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/239400-cpus-and-mobos-help/#findComment-3282772
if you aren't planning on overclocking get a H97 board. They're cheaper but don't allow for overclocking
-BUILD-
CPU: INTEL I5 4690K GRAPHICS CARD: GIGABYTE 970 G1 2.5GB CASE: NZXT S340|BLACK MOBO: MSI Z97S KRAIT EDITION CPU COOLER: CORSAIR H100i
 RAM: HYPERX FURY 2X4GB|WHITE PSU: CORSAIR RM850 850W FULLY MODULAR STORAGE: 1TB WD BLUE HDD OS: WINDOWS 8.1
https://linustechtips.com/topic/239400-cpus-and-mobos-help/#findComment-3282822
I have an Athlon 760k with a R9 280. (get decent fps in battlefield 4 on high) They don't bottleneck each other. And the Athlon 760k is a weaker cpu than the i5 4440 so there shouldn't be a bottleneck. As for the motherboard, I haven't looked much into intel but I would go with jeman99 and get a z97 for future proofing.
https://linustechtips.com/topic/239400-cpus-and-mobos-help/#findComment-3282830
can this cpu OC?
No, only the K series can overclock(ones with a "K" at the end of the name).
-BUILD-
https://linustechtips.com/topic/239400-cpus-and-mobos-help/#findComment-3282842
so i should get an h97 mobo?
the i5-4440 not being an haswell refresh you have freedom, any H81, B85 or H87 motherboard would do as well so get the cheapest available and save some more.
This one would do the job just fine and as a good price:
http://pcpartpicker.com/part/asus-motherboard-h81mdplus
Are you planning on using dual GPU's down the road?
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/239400-cpus-and-mobos-help/#findComment-3283569
Nope a 280 will do perfectly fine with a 4440. Also since the CPU can't be overclocked, you can get any LGA1150 motherboard you like. Even the $50 H81 boards will do fine.
"Rawr XD"
https://linustechtips.com/topic/239400-cpus-and-mobos-help/#findComment-3283597
