hey linus community I am building a new pc and was wondering the size and amount of radiators I need. Just place your vote in the poll and this will help me heaps. Or if you have another opinion which I have not listed please feel free to live it in the comments.
http://au.pcpartpicker.com/p/nZdLbv
i am making my custom water cooling loop for my new pc. I was just wondering if the following parts were compatible.
http://www.pccasegear.com/index.php?main_page=product_info&products_id=25308
http://www.pccasegear.com/index.php?main_page=product_info&products_id=24482
http://www.pccasegear.com/index.php?main_page=product_info&products_id=29154
http://www.pccasegear.com/index.php?main_page=product_info&products_id=29066
http://www.pccasegear.com/index.php?main_page=product_info&products_id=21838
http://www.pccasegear.com/index.php?main_page=product_info&products_id=22154
I will be using a gtx 980, 5930k and a 750d case
Thanks
Wolffangs147
post-146291-0-79025400-1414297455_thumb.
Its when dragons have so much sex that the cpu cant handle it
https://linustechtips.com/topic/239150-water-cooling-compatibility/
All of that will work, just make sure you have the coolant you want(if you want it), or you can get distilled water and a biocidal agent, or a piece of silver. Also make sure you have 8 fittings(9 to be okay)
I'm going to use the distilled water as it is quite cheap and I knew I was going to need 8 fittings but thanks anyway :)
I'm pretty proud of myself that was my first time I picked all the parts by myself and they are all compatible yay me! Btw I will have 2 radiators
looks good :D awesome colour choice
How much wattage will that pull and what power connector do I use
Go for as much Surface area as you can in the rads.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
Thanks
Wolffangs147
Which case are you going to use? Cant really give an answer unless the case is known.
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
since the roof clearance is short for a 360x 60, the XT45 360 in the roof is a
comparable compromise. depending on how hard your overclocking voltage
being used will surely dictate the fan selection. to counter this issue, adding
a 2nd radiator XT45/UT60 in the front will easily ensure a low speed/noise
usage. but one caveat would be the 750D ability to restrict the front intake for
the radiator. MNPCTech has a solution:
corsair_750D_front_plate_vented_vent_hol
http://mnpctech.com/mnpctech-clear-case-pc-panels/corsair-750d-front-plate/corsair-750d-cnc-milled-vented-front-bezel-plate.html
