For a project, i have to create a program that can order food and add up all the totals. I am stuck on how to create a loop when the user needs to order the food. This is what i got so far:
package project.pkg1;
import java.util.Scanner;
public class Project1 {
    public static void main(String[] args) {
     int choice = 0;
     String order;
     Scanner Keyboard = new Scanner(System.in);
     double num;
     double GoodBurger = 7.75;
     double GoodSalad = 7.00;
     double Soda = 2.00;
     double KidsMeal = 3.00;
     double tax;
     double subtotal = 0, total;
     final double salestax = 0.875;
     System.out.println("Welcome to Good Burger!");
     System.out.println("=======================");
     System.out.println("Place your orders and type 'Finish' when you are done");
     System.out.println("--------------------------------------------------------");
     System.out.println("1. GoodBurger $7.75");
     System.out.println("2. GoodSalad $ 7.00");
     System.out.println("3. Soda $2.00");
     System.out.println("4. KidsMeal $3.00 \n");
     choice = Keyboard.nextInt();
What do i need to do?
https://linustechtips.com/topic/238942-need-help-with-loops/
Add a boolean for "doneOrdering" and put the item selection in a while loop.
While(doneOrdering == false) (Can also do "While(!doneOrdering))
When finished is entered set the boolean to true so you can continue to something else.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277050
boolean done = false;
while (!done){
    Take order.
    set done = true upon completion of the order.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277051
So, will it print out the list of food that the user will write until it says done?
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277081
It will print out the list of food and accept inputs until finished is triggered.
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277088
do i put the list of food in inside the while loop? like how would it look like?
Does Java have a pre-defined update function that is called 60 times per second?
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277143
Not going to code if for you but should look something like this:
package project.pkg1;import java.util.Scanner; public class Project1 {    public static void main(String[] args) {     	 	 	 int choice = 0;     String order;     Scanner Keyboard = new Scanner(System.in);          double num;     double GoodBurger = 7.75;     double GoodSalad = 7.00;     double Soda = 2.00;     double KidsMeal = 3.00;     double tax;     double subtotal = 0, total;     final double salestax = 0.875;          System.out.println("Welcome to Good Burger!");     System.out.println("=======================");     System.out.println("Place your orders and type 'Finish' when you are done");     System.out.println("--------------------------------------------------------");    	 //WHILE(BOOL IS TRUE)	     System.out.println("1. GoodBurger $7.75");     System.out.println("2. GoodSalad $ 7.00");     System.out.println("3. Soda $2.00");     System.out.println("4. KidsMeal $3.00 \n");     choice = Keyboard.nextInt();	 	 //ADD THE CHOICE PRICE TO A VARIABLE THAT CONTAINS TOTAL	 	 //ASK USER IF THEY WANT TO ADD MORE. USE IF STATMENT TO DETERMINE.	 //IF USER WANTS TO STOP, SET BOOL TO FALSE	 }
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277242
     int choice = 0;
     String order;
     double num;
     double Soda = 2.00;
     double tax;
    while(!done){
         choice = Keyboard.nextInt(); //user enters the order and then finish.
          if (choice == 1) {
                       subTotal += GoodBurger;
          else if (choice == 2) .............and so on.
          else if (choice == 5) done = true; //Because you're using .nextInt() you're reading ints, not strings, so I        don't think "finish" will be read (I may be wrong though...not sure)
PSU Tier List | CoC
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277252
     int choice = 0;
     String order;
     double num;
     double Soda = 2.00;
     double tax;
    while(!done){
          if (choice == 1) {
what if i wanted to use words instead of numbers? can i replace 1 with something else?
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277354
You could use TextIO.getln(); which just reads a line from input. And make the user input the name of the item being ordered. So, if he wanted to order a goodburger and a goodsalad, he would type goodburger then hit enter, the program would recognize the input and add goodburger to the order, and then he would type goodsalad and hit enter.
Something like this:
       while(!done){          choice = TextIO.getln(); //user enters the order and then finish.           if (choice.toUpperCase.equals("GOODBURGER")) { //.toUpperCase capitlizes the entire string --        //alleviate user input errors.                      System.out.println("1. GoodBurger $7.75");                      subTotal += GoodBurger;          }          else if (choice.toUpperCase.equals("GOODSALAD")) .............and so on.           else if (choice.toUpperCase.equals("FINISH")) done = true;          else                System.out.println("I'm sorry, I do not recognize that);     }}
PSU Tier List | CoC
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277376
-double post - ignore
PSU Tier List | CoC
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277392
       while(!done){          choice = TextIO.getln(); //user enters the order and then finish.           if (choice.toUpperCase.equals("GOODBURGER")) { //.toUpperCase capitlizes the entire string --        //alleviate user input errors.                      System.out.println("1. GoodBurger $7.75");                      subTotal += GoodBurger;          }          else if (choice.toUpperCase.equals("GOODSALAD")) .............and so on.           else if (choice.toUpperCase.equals("FINISH")) done = true;     }}
so i did what you said but it's not working http://puu.sh/cqv6f/858f4c2fce.png  do i need another scanner or string?
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277470
what do i write when the boolean is true? the orders?
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3277673
What IDE are you using to code? Usually if you hover over the red line it will display some suggestions.
If you wanna read in a String you can use Scanner.nextLine();
I would not recommend this though as it means validating the option would be more difficult than asking the users to make a selection from an int or a char.
As for the while loop bit based on your last post, while the condition is true keep prompting the user to make a selection, read the selection and add the order according to how you were doing it. If the user is done, set the boolean to false and handle it accordingly.
https://linustechtips.com/topic/238942-need-help-with-loops/#findComment-3281548
