Looks Great, I cant find anything bad with it.
What OS are you going to use?
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/238936-mid-range-800-build/#findComment-3277004
I would recommend at this price range, a intel i5 4590/4690. if you want to keep the amd thing, just up your psu to 750w - 800w so you can crossfire another 280x in the future since your motherboard supports it.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/238936-mid-range-800-build/#findComment-3277006
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($139.97 @ OutletPC)
Motherboard: Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard  ($109.99 @ Newegg)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($194.99 @ NCIX US)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($39.69 @ Amazon)
Total: $800.83
Generated by PCPartPicker 2014-10-25 17:14 EDT-0400
"an obvious supporter of privacy"
https://linustechtips.com/topic/238936-mid-range-800-build/#findComment-3277026
CPU: AMD FX-8320E 3.2GHz 8-Core Processor  ($134.99 @ Amazon)
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard  ($99.99 @ Amazon)
Memory: Apotop 8GB (2 x 4GB) DDR3-1600 Memory  ($65.70 @ Newegg)
Video Card: HIS Radeon R9 290 4GB IceQ X² Video Card  ($229.99 @ Newegg)
Case: Cougar Solution (Black) ATX Mid Tower Case  ($29.99 @ Newegg)
Case Fan: LEPA Vortex 12 PWM 63.9 CFM 120mm  Fan  ($1.99 @ NCIX US)
Total: $796.52
Generated by PCPartPicker 2014-10-25 17:19 EDT-0400
R9 290. Because you're worth it....or whatever. You can afford it at least.
https://linustechtips.com/topic/238936-mid-range-800-build/#findComment-3277058
Your build is wonderful!  If your interested here is another Intel/Nvidai build (max bang for buck)
http://pcpartpicker.com/user/Weak1ings/saved/CxTFf7
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/238936-mid-range-800-build/#findComment-3277108
Total: $796.52
How does this help him in anyway he asks something about his own build. Instead of just giving another build under 800 dollars mabye look at what he made and say where he can save money. What if he doesn't want your cheap case and why in gods name a 1000W PSU, WHY? Because he should really run a r9 290's in crossfire that is so not wastefull god. Sorry but I have been here for 3 days and every post you do the same thing sometimes usefull and sometimes just absolute unnecessary.
@OP: Build looks good for the budget you have.
https://linustechtips.com/topic/238936-mid-range-800-build/#findComment-3277123
Any suggestions or advice is greatly appreciated! :D
That is why I posted it. The original post is vague, so vague I cannot tell if he means "I plan to build this" or "I have built this". Either way, it's a suggestion for a better build. And if he did plan to crossfire a pair of R9 290's, nothing wrong with this. At higher resolutions the Hawaii cards do very well.
https://linustechtips.com/topic/238936-mid-range-800-build/#findComment-3277211
Well if you read he wants advice so he probably hasn't build it yet so recommending specific parts would be better and he could have elaborated his post a bit but still why the gigantic PSU and why the change of Case. Especially the case is a personal choice some do care about what they pick asthetic wise. Anyway both builds are good but he should take his CPU if he doesn't want to over clock.
https://linustechtips.com/topic/238936-mid-range-800-build/#findComment-3277415
