Two 8-pin CPU headers?
My ASRock Z97 Extreme9 comes with two 8-pin CPU headers while other boards I've looked at (such as the Extreme6 or Extreme4) only have 1.
My PSU has two 8-pin CPU cables (one comes pre-attached in a 4+4 pin arrangement and the other is a special 8-pin cable that has 10 pins at the PSU end) but I've removed one because it was in the way of my H100i (with 4 fans attached).
Since all of the boards are compatible with all LGA 1150 socket CPUs I'm assuming you only need 1 for it to work so what is the purpose of the second header?
Thanks.
The more you overclock, the more power the CPU will use. You see this when you increase your voltage.
However with voltage increase comes current increase. Current can cause heat in cables (energy loss, cause every cable has inherent resistance.)
To combat this, many cables are thicker and redundant (for example, multiple cables for positive and multiple cables for negative terminals)
However, headers can only have limited current capability without becoming thicker, so the extra header can basically improve maximum current transfer.
You'll probably not need this at all; I'm pretty sure 8pin is already redundant enough.
