Hey guys,
For a while now i've been enjoying CM11 and android in general on my nexus 5, but MAN, the low battery vibration is a pain in the ass. I don't usually plug my phone in in the weekends because I don'T use it much on the weekends and whenever the battery will drop under 15%, it will vibrate.
Is there any way to disable that stinkin notification that ALWAYS,  with no exceptions, will wake me up in the middle of the night. (Great when you have exams the next day)
I would really like to know. I already searched the web and haven't found much on the subject.
Thank you
https://linustechtips.com/topic/238770-low-battery-vibration-android/
From here:
http://forums.androidcentral.com/lg-optimus-s/98603-there-anyway-turn-off-annoying-low-battery-warning.html
I've found this app, which might be worth trying:
https://play.google.com/store/apps/details?id=com.appsideout.silentbattery
I'll keep on searching and edit this if I find anything.
Sig under construction.
From here:
Thanks a lot, i'll try it out
I'll install CyanogenMod on my n5 in a bit (gotta let it finish dling.)
I know for a fact on Paranoid you can do Settings>Battery>alert-ish icon>then choose how you want it to do that alert. That's a bad explanation so you can watch this.
EDIT: You could probably use quiet hours to disable vibration (there's an option in there) during [x] time to [y] time. Settings>Sound>Quiet Hours.
could always put it on silent mode :3
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
Don't think it works. Pretty sure it already vibrated when low battery while on silent mode
guess that is a feature on samsung phones cause i know my note 3 doesn't :L
Current Build :
Laptop:
 CPU:
