can someone help me with taking my aoc i2369vm apart? or just the stand so i can mount it to a desk mount?
Well, we can't physically be there to help you, but we can guide you through it. Well someone can, I wouldn't have a clue. :D
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/238261-aoc-display-help/#findComment-3268577
As far as I can tell the monitor is VESA compatible, so there should be a way to remove the stand.
On the pictures I could find, it looks like the stand is either screwed or clicked on the monitor, behind a small plastic cover.
Now, I haven't had any personal experience with this monitor, so I might be wrong. Just keep in mind, that if it doesn't come apart, it probably shouldn't.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/238261-aoc-display-help/#findComment-3268611
yeah
yeah, i dont want to break it, just don't have a clue how to get that wee tab off
https://linustechtips.com/topic/238261-aoc-display-help/#findComment-3268636
yeah
Do you have the manuel?
Edit: The manuel doesn't help.
post-5244-0-21774600-1414166952_thumb.jp
According to a comment on this video
you have to remiove the black cover, and unscrew the stand.
https://linustechtips.com/topic/238261-aoc-display-help/#findComment-3268687
Cheers but I don't get how I get the tab off?
Now I'm a bit confused?
What do you mean with "tab"? Do you mean the stand that is left after you take off the base?
https://linustechtips.com/topic/238261-aoc-display-help/#findComment-3268761
Sorry the wee bit at the back protecting the stand arm
That I can't help you with, sorry.
It  is supposed to be removed, so there has to be way to do it.
My best guess, is that it's clicked into place, and it might take a bit of force to remove it.
https://linustechtips.com/topic/238261-aoc-display-help/#findComment-3268892
