[Help Needed] Creating a Backup System
The highlighted questions are about the backup servers, i cant help you there.
question number 2, so you mean RAID software or backup software?
question number 3, depends on how big the server needs to be.
do you know how big the array needs to be?
I recommend you to look at the link in my signature (10TB+ storage topic) you can get some hardware inspiration there.
Thanks for your reply, with the question about software I was referring to do the backup itself, but we looked into it and we made a little code to backup a specific folder of the computer and we integrated it in the program we use to monitor when and how much we are working (like the time card you stamp at the beginning and the end of work turn, but in our case it's an usb drive and it stops counting the time worked after five minutes of inactivity). For the servers we figured out that a backup limited to the sensible data is more logical compared to a full system backup. The sql server is already configured to do a full backup of the databases every day (we opted against incremental/differential) and it will always keep seven of them (one per day of the week).
We are currently setting up backup methods for Exchange, Tema Fonudation Server and Share Point.
At the moment the machine storing the data it's an old desktop with 2 3TB HDD in raid 1 but we already ordered the pieces for a machine that will use more disks and a dedicated RAID controller for RAID 6.
Thanks for your help :D
