help
Go to solution Solved by kreft010,
If you feel lazy or don't know your specs you can try this http://www.systemrequirementslab.com/cyri
What is the best way to tell how well my PC will be able to run a game if at all
By running the game.
/Look up what hardware you have and see how it performs in said games.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/238092-help/#findComment-3265539
Read the back of the box / minimum requirements on the game page
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/238092-help/#findComment-3265541
look at benchmarks and actually trying out the game and messing with the settings
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/238092-help/#findComment-3265575
well i mean you can kinda tell right off the bat, if youre hardware is junky and low-end, then expect a sorta junky experience in demanding games :P
https://linustechtips.com/topic/238092-help/#findComment-3265614
MSI X99S SLI PLUS  // Intel Core i7-5960X Processor (8 x 3.0 GHz) // Corsair Hydro Series H80i Cooling // 32 GB DDR4 High End Crucial 2133 MHz RAM
2 x 4096 MB NVIDIA GeForce GTX 980 //2 x 500 GB SATA III Samsung 840 EVO SSD // 4000 GB SATA III, 7200upm // 1000 Watt Silverstone Strider SS //Creative Sound Blaster Z
Cooler Master Cosmos II Big Tower (ATX)
https://linustechtips.com/topic/238092-help/#findComment-3266409
