Disable the onboard GPU in the BIOS.
Have you tried disabling the onboard video from the BIOS menu? If you haven't done that yet I suggest that you do. With the lack of information about your specs I can't for sure say what the issue is and I have no idea if you're running an APU or just onboard video from the mobo.
MOBO - Asus Sabertooth 990FX R2.0   CPU - AMD Phenom II X6 1055T @ 3.5GHz - Corsair H80i   RAM - 2x Corsair Vengence 4GB DDR3 @ 1666 MHz
GPU - SAPPHIRE 100362-3L Radeon R9 290 4GB Tri-X OC  Sound - ASUS Xonar DSX  PSU - Thermaltake SMART M Series SP-850M 850W
Or boot up with just the onboard gpu and the disable stuff as needed.
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
This. And make sure your GPU drivers are installed correctly, reinstall if necessary, had a similar problem with a laptop once, where the autoupdate would install VGA and ignore the GPU.
Frost upon these cigarettes.... lipstick on the window pane...
