Operation Quick Fix
So my motherboard has gone a bit dodgy and no longer accepts more than 1 stick of RAM without failing miserably, as it stands it fails with 1 stick most of the time, so I had to RMA it and set up a bit of a temporary solution in the meantime, I apologies for the terrible photo quality, my phone is supposed to have a great camera (like most phones) but (like most phones) its actually rubbish.
So here is my temporary build with a M-ATX motherboard (placeholding until I get a new one) I have also had to remove a graphics card due to the fact the slot to plug it in was not physically available.
ASUS Maximus V Gene
Intel Core I7 3770
Crucial Ballistix Tactical Tracer 4x4GB sticks (completely overkill I barely use 8GB but hey, the lights look cool!)
Corsair H80I with a failed LED that don't work no more :(
XFX HD7970 (should be two but other one will sit in box until I get new motherboard)
Killer 2100 (old motherboard had REALLY bad onboard lan and this was cheap and out-performed onboard by quite a lot, I realize with this motherboard the Intel LAN is probably as good)
Creative Sound Blaster Recon3D Fatal1ty Champion
Enermax Revolution87+ 1000W PSU
Various HDDs, SSDs, and Hybrid Drives.
Fans are as follows: Front - Bitfenix Spectre Red LED 200mm, Top - Enermax 120mm T.B Apollish Red LED, Rear/Rad - Silverstone Air Penetrator 120mm Red LED
post-9163-0-29555300-1370469858_thumb.jp
In Progress of build with M-ATX Motherboard
post-9163-0-05664700-1370469900_thumb.jp
Everything installed, just need the finishing touches and some rubbish but suitable for now cable management.
post-9163-0-30475700-1370469840_thumb.jp
Rubbish photo which made my camera struggle even more than usual thanks to the lights.
post-9163-0-06160300-1370469884_thumb.jp
https://linustechtips.com/topic/23687-operation-quick-fix/
Hahaha that bit about the phone's camera made me laugh. . . I plan on buyin that Asus board tomorrow. How do you find it? Do u like it?
:) Nice build btw
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/23687-operation-quick-fix/#findComment-300652
:) Nice build btw
Its a nice little board if thats what you want, if you want a big gaming PC with two graphics cards etc I don't think its the best option mainly because of the slot layout and me not being keen on multi GPU setups having no spacing in between them, aside from that though I really like it, onbaord LAN is pretty outstanding the onboard audio is good enough to warrant not needing a soundcard unless your super fussy about audio quality.
https://linustechtips.com/topic/23687-operation-quick-fix/#findComment-301914
Yeah man, I've only got a Micro ATX case, and will not be CF/SLI'ing or anything. . .  Kool :) thanks
https://linustechtips.com/topic/23687-operation-quick-fix/#findComment-302300
