Mouse Hardware Acceleration
Go to solution Solved by Altecice,
I play a lot of fps games, but is a good laser sensor going to have very noticeable acceleration? I heard only about 4-5%, which is very small. 180 spin would just be 189 degrees.
Its more for muscle memory. if you are getting shot from X location then with no Acceleration you know how much to move the mouse to get a perfect headshot on the person. vs Acceleration where it wont always go back to that same location. so there is some guesswork involved. Its not much but if you are playing Professional then every millisecond makes the difference.
it doesn't matter for average gamers. But if you play alot of FPS games then you really want an optical mouse with no acceleration.
laser = built in acceleration
optical = none
Quack 🦆
Ok, thanks. I am far from a pro player, and I'm sure I can deal with a bit of acceleration.
