okay so there is a problem with my computer of shutting down randomly like just moments ago working then the shutdown screen comes and the computer just shuts off and there is also a problem with programs randomly starting i tried to scan the computer for any viruses and there is nothing ,the temps are normal 50 C are max,  i tried to install a fresh copy of windows and the same problem i even tried to install Linux Debain and the same thing happen again this is so crazy please i need your help
Manners Maketh Man
https://linustechtips.com/topic/236533-need-help-the-computer-is-going-crazy/
Thermal thresholds may be set low. Note any overclocks you have, then reset your bios (removing battery on mobo)
Is it BSOD or just straight up power down?
Other possibilities: PSU going bad, Hard drive failure, exposed trans-dimensional rift near PC
317 is watching. 317 is everywhere. 317 is life.
I had the same issue, some weeks ago and it turned out to be the PSU going bad. You have to think about a new one.
My synonyms were:Random crashes in idle and under load. Not able to reproduce it in any scenario. Shuts down like you would pull the plug.
Java Programmer, AMD Fanboy and soon to be casemodder
