So i just recently noticed that my mechanical keyboards spacebar has got an odd sound when i bottem out the key. I noticed that my keyboard has an "odd squeaking sound" this being my best way to describe it. I have an TtSports Posidon Z Cherry Mx Blue keyboard and i would like to know if anybody has had a similar problem and knows how to fix it. I think it might have to do with the spring in the spacebar but i have never taken apart my keboard or anything because i have never had a reason so i would not know. all i know is that it hurts my ears and i would like to know how to solve it
https://linustechtips.com/topic/235876-mechanical-keyboard-problem/
I would suggest lubing up your keyboard....
Listen to Luke here:
http://youtu.be/NADlUip6lMY?t=12m54s
oh and before that he shows you how to take it apart.
All in all a VERY useful video if you are a noob/ don't know everything about mks yet :)
PROFILEYEAH
What do people even put in these things?
You may need to lubricate the stabilizers on your space bar, might as well do the rest of the stabilized switches while you're at it ;)
http://imgur.com/a/lhLqo
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
