Will it fit?
Go to solution Solved by MasterRaceFanBoy,
Will a Z97 Gigabyte HD3 sli fit in my case-Sharkoon BD28?
yes. it support atx mobo's, and your case is an atx case. that is what you need to check, mATX, ATX etc.
The blood on to your heart start pumping faster when you notice me.
But is ok.
Judge me for my nickname, my avatar and for the low amounts of posts I have. I will keep your heart beat raised.
https://linustechtips.com/topic/235520-will-it-fit/#findComment-3227017
