Hello
I have recently bought a new computer and was setting it up to find that one of my hard drives wasn't working, now I have contacted the store I bought it from and they have no idea what going on and I have also googled it and there isn't any relavant information on this issue.
The issue is I'm unable to see the Hard drive at my computer screens, now I thought it would be as simple as formatting it like I usually do however that's not the case I went into disk management and the system format for this Hardrive is CDFS which I googled and its a DVDS format which I have no idea how the hardrive got like that in the first place but anyway, I have tried deleting it but it says I'm unable to and I have also tried many commands on CMD and it hasn't worked.
If possible I would like to skype someone to get this issue resolved.
I am running windows 7 as a operating system
https://linustechtips.com/topic/233364-please-help/
This is a weird one indeed.
Have you tried formatting it on another computer? It might just be your Windows install that is acting up.
When you say you have tried through CMD, do you mean Diskpart?
If the HDD arrived like this, then you should be able to RMA it. It might be a mistake form the factory.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/233364-please-help/#findComment-3188571
If formatting the drive isn't working I would try using it on another computer and trying tot do it there
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/233364-please-help/#findComment-3188575
the issue is this is the only computer in my house besides ipads, as i said in the thread is someone able to use teamviewer or skype and help me out as im completely stuck and dont wanna pay another $100 for the techs to fix this issue.
First of all, remember to quote the person you want to talk to. That way they'll get a notification, and you'll get a faster response.
Unfortunatly I am not able to use Skype, as I am at work at the moment, and I won't be home for 5+ hours.
Can you use a friends computer possibly?
Since you didn't asnwer my question about Diskpart, here is a giude on how to use it:
If the drive arrived like this, you shouldn't pay a tech $100+ for fixing it. You should RMA it.
https://linustechtips.com/topic/233364-please-help/#findComment-3188623
I did disk part it but it doesnt want to seem to work for some reason, not sure why tho
https://linustechtips.com/topic/233364-please-help/#findComment-3188659
I'll do a Skype call with you to try and figure this out, granted I may not be much help, but I'll do my best! Message me your Skype name.
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
https://linustechtips.com/topic/233364-please-help/#findComment-3188950
I had this same problem when I tried to format the hard drive that came with a HP computer my son bought.  We upgraded his hard drive for Christmas and we were going to use the original for storage but it says you do not have permission to do this.  We had to put it in my computer to format it and it worked fine after that.  I think they do this to protect the end user and keep them from loosing the restore image stored on the drive.  Let me know if this is what you are trying to do.  I don't care a bit to Skype with you if it helps.
Bird
https://linustechtips.com/topic/233364-please-help/#findComment-3189230
