You could always try to change your mic config...
Maybe putting it as far away from your keyboard as possible or making it capture just really loud sounds but you'd probably have to speak louder too.
O-rings will help but I believe the clicky sound will still be there.
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/233235-blue-switches-problem/#findComment-3188952
"Please help, my MX Blues aren't like MX Browns"
You can eliminate the problem with a more directional boom mic. At least I really hope you aren't using a table or lapel mic (?)
And if you do have a boom mic on a proper headset, are you at least keeping the keyboard in front of you and not in your lap?
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/233235-blue-switches-problem/#findComment-3188989
