I need help!
Go to solution Solved by brob,
Nope didn't work
You might try clearing the CMOS - see the user manual for details. The process is run with no power to the motherboard so make sure that the psu is turned off on the back.
So i built this system last night and i did a post every thing turned on. So i came back to finish up some cable management and it wont stay on ( powers on for a split second and then turns off) I have checked and all of the cables are plugged in. What do i do??
Parts that were in this build:
PCPartPicker part list: http://ca.pcpartpicker.com/p/v9trwP
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (Purchased For $0.00)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($0.00)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  (Purchased For $0.00)
Memory: Kingston Fury Red Series 8GB (2 x 4GB) DDR3-1600 Memory  (Purchased For $0.00)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  (Purchased For $0.00)
Video Card: MSI GeForce GTX 760 2GB TWIN FROZR Video Card  (Purchased For $0.00)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: Corsair RM 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (Purchased For $0.00)
Case Fan: Corsair Air Series AF120 Performance Edition 63.5 CFM 120mm  Fan  (Purchased For $0.00)
Case Fan: Corsair Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM 120mm  Fans  (Purchased For $0.00)
Case Fan: Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm  Fan  (Purchased For $0.00)
Total: $0.00
Generated by PCPartPicker 2014-10-14 20:37 EDT-0400
https://linustechtips.com/topic/233208-i-need-help/
Check to see if all the components (ram, gpu, etc) are plugged in properly and re-plug in all of the power cables just to be sure they are all plugged in
CP: Ryzen 7 2700x | Motherboard AsRock B450M | RAM 32GB Corsair ddr4 | GPU EVGA (RIP) 1070ti | Case Corsair Vengeance C-70 Black | Storage 512gb Samsung NVME ssd | PSU EVGA 850w Platinum | Display Asus PB258Q 1440p
| Cooling Noctua NH D15 | Keyboard Cooler master mechanical kb with blue switches | Mouse Logitech G502 | Sound Beyerdynamic DT 990
| Laptop Maingear Vector Pro 2 (Ryzen 9 6900xh, Nvidia 3070t, 32gb ram)
https://linustechtips.com/topic/233208-i-need-help/#findComment-3186821
Often this is caused by a cpu cooling failure. Check that the pump/interface assembly is securely mounted on the cpu. Verify that the radiator and pump are plugged in and getting power.
https://linustechtips.com/topic/233208-i-need-help/#findComment-3187128
