Here is what I am thinking of building but I have a few questions.
First, here's the link to the list
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=19630174
First question: What graphics cards can i crossfire with this APU with, if any?
Second question: I have a spare 500 GB 2.5 inch hard drive that i would like to use, can i mount this as an SSD or will it cause vibrations?
Third question: Is 550 watts too much wattage if i at most will be adding one graphics card.
Fourth question: Would it be better to start off with 2x4GB kit or a 8GB stick?
Any other suggestions on my build would be greatly appreciated! :)
https://linustechtips.com/topic/233009-my-first-gaming-build/
1. Can help you with this sorry, but maybe the R7 line? IDK
2. You can mount it on the 5.25' cage, I have one installed on my CM E130
3. 550W is enough, but 450W should be fine
4. 2x4GB ;)
"an obvious supporter of privacy"
https://linustechtips.com/topic/233009-my-first-gaming-build/#findComment-3184468
1) If you want to crosfire later, get a 7850k, the 5800k is 2 generations old.
2) It should be fine.
3) that looks fine too
4) 2x4.
EDIT: APU's like fast RAM. http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460&cm_re=1866_ddr3-_-20-231-460-_-Product
I could be very wrong
https://linustechtips.com/topic/233009-my-first-gaming-build/#findComment-3184537
That Memory is really well done, once again G.Skill never seems to stop impressing me.
Because he had a hard drive.
https://linustechtips.com/topic/233009-my-first-gaming-build/#findComment-3186563
